philfingers
- Bike owned: NC30 Type 7
Re: HELP! i have a BIGGER problem now!
mig should be fine
The different types of weld are not based upon the strength of the weld.xivlia wrote:okay, i decided to go with welding a nut on the broken thread...but can anyone tell me which weding i need to use? TIG welding or something weaker or what?
thanks guys.
The stud is a steel nut, you could use tig, mig or an arc-welder, oxy-acetaline or maybe even a braized on nut might be strong enough.
Find somebody who has and knows how to use a welder, you only need to tell them it's a steel stud and a steel nut and they should be able to help
- xivlia
- Bike owned: Ducati 749 D
ahh oaky, my uncle has a welder i dont know which type so il ask him to do it for me though.
Ok well any welder will be able to do that... just tell him you have a steel stud and want a nut welding onto it so you can undo it and then he should be able to oblige!xivlia wrote:ahh oaky, my uncle has a welder i dont know which type so il ask him to do it for me though.
Spray plenty of releasing fluid / i.e. plus-gas onthe the threads for a few days before you remove it.
- xivlia
okay, i also have this easier option for welding...my dad has a LPG fuelled welder (a gas tank and a flame)...i think it reaches about 750 degrees C .. and another one my dad has is this...http://www.ebay.co.uk/itm/Oxy-Turbo-90- ... 0572473748 its says it reacher 3000degrees C...would that be fine to weled a nut on the broken screw? or would i need something more powerfull than that? my uncle has an arc and a tig welding machine but i dont see him that much so i was just wanted to ask about the easier one.
hunter
If it's only the remains of the one stud in the pic that you have to remove you could probably braze a nut on,but i don't think you will weld with that kit.the best welder to use for this type of work is a mig.
philfingers
you'd do it with gas but a mig would be easier, 10 mins of setting up and a 10 sec zap would have mine done
Yes you can weld with Oxy Acetaline
You could braize with the propane.
do not do this yourself. get somebody who knows how to use them to do it, they will know what they are doing.
- xivlia
okay. my uncle said hed come and use his arc welder on it. ermm just wondering what size of nut would i need for the thread? i dont know the size of the screw and it doesnt say it on them..
You dont' need to screw the nut on... anything that you can put a spannr on will do, so long as it isn't stupidly big, just weld it on.
For a nut to fit (screw on) there M8's which is a 6mm thread, can't remember the pitch off hand.. maybe 1.0
