anyone got a spare one of theese??..
- xivlia
- Bike owned: Ducati 749 D
the thing that pushes the choke rods out when you put the choke on... here is a pic.
basically mine is kinda fucked.the threading in it is broken. i cant put screws in it...i took the original screw out to take the rod out for a clean. and when i put the screw back in.. it went in at an angle and ruined the threading and now screws just slide off of it.
VFR400+
Re: anyone got a spare one of theese??..
Could always retap it for a bigger bolt if no one comes forward.
- xivlia
i could yea. but id rather have a nother one as its easier option
- skinnydog0_0
- Bike owned: Penny Farthing
I agree with Snark, you will probably end up having to get a full set of carbs for that part. If you get a tap and die set you have it fixed and you get some more new toolsSnark wrote:Could always retap it for a bigger bolt if no one comes forward.
- BillingCBR
Pretty sure someone wanted that off me but never took it, ill dig around my box of spares in the morning and see what I can do
- xivlia
ahhh nice! if you find it let me know :DBillingCBR wrote:Pretty sure someone wanted that off me but never took it, ill dig around my box of spares in the morning and see what I can do
think its an M4 bolt if that helps :D
kevprojex
- Bike owned: ktm200exc gsxr400gk71b sv650
i have a set of carbs i use for spares you can have one off .
- xivlia
cool how much will you charge for the thing that holds the choke rod? :)kevprojex wrote:i have a set of carbs i use for spares you can have one off .
kevprojex
if you collect it you can have it , or ill stick it in the post 4u , not back in the unit untill tuesday so as long as you are not in a rush for it , pm your address and ill sort it out next week 4u.
