nc30 carbs refitted, HELP
burningalive409
Post by burningalive409 » Wed Sep 28, 2011 1:15 pm
I finally got my carbs fitted back on my bike last night after putting the restrictors on, and after that I quickly put the bike together to start it, and nothing! :( could this be due to wd40 in the cylinder heads? (From fitting the carbs into the rubbers :P) or what? Help plesae, want to get it running asap!
Hadies
Re: nc30 carbs refitted, HELP
Post by Hadies » Wed Sep 28, 2011 1:50 pm
Nothing as in nothing happens when you press the button or it just won't start?
Full choke, no throttle. If that doesn't work then dead plugs maybe. Check for spark and fuel.
Post by Neosophist » Wed Sep 28, 2011 2:32 pm
Dry carbs take a while to fill up.
Make sure the vaccum tap is connected properly.
Full choke no throttle, crank in 5 second blasts with two minutes in between, it'll catch after a while
burningalive409
Post by burningalive409 » Thu Sep 29, 2011 8:33 pm
Thanks guys, got it started trying that. Buuuuut now have another problem! The bike only runs with the choke on, but instead of being up around 5,000rpm it sits at 1 and a half? Also loud abnormal engine noise from right side of bike, close to carbs and strong smell of exhaust fumes, carb not seated properly? Is it as simple as push some some to get it seated, or can I use some form of sealant? Or both?
skinnydog0_0
Bike owned: Penny Farthing
Post by skinnydog0_0 » Thu Sep 29, 2011 8:43 pm
I would take the carbs off and re-fit using proper rubber grease. make it much easier. ;)
Neosophist wrote:Dry carbs take a while to fill up.
:plus:
lizard821000
Post by lizard821000 » Thu Sep 29, 2011 9:04 pm
you havnt mucked around with your airscrews by any chance....
burningalive409
Post by burningalive409 » Thu Sep 29, 2011 9:41 pm
Nope. Didn't touch anything I didn't have to
lizard821000
Post by lizard821000 » Thu Sep 29, 2011 10:17 pm
id say there were seated right, or youd most likely have a higher idel, not low.
burningalive409
Post by burningalive409 » Thu Sep 29, 2011 10:46 pm
Ok, what about the leaking exhaust fumes on the right hand side? All I've done is taken off the carbs and replaced the rubbers, and it ran fine before that
lizard821000
Post by lizard821000 » Thu Sep 29, 2011 11:00 pm
fumes prob just wd40 burning off with warm up, keep an eye on it, see if it goes away. you didnt leave anything in the holes etc when you re-fit? i put paper towels down my heads etc when my carbs where off to stop shit falling down incase, prob somin little youv over looked thats all.
