NC30 Carb Needles
NC30 Carb Needles
Hi, just giving my bike a bit of service to see why theres a missfire about 7K. Anyway i took slides out to see if the diaphrams were split or anything and the needles dont point straight up, parallel to the side of the slide, they lean towards the little hole in the bottom of the slide. I've ever seen this before, all the carbs i've taken to bits before the needle sits straight to the slide, so i wondering if me slides have worn somehow?
Hope you can see wat i mean?
Ian
Ian
Re: NC30 Carb Needles
Anbody have a clue? i dont want to buy more slides if there all like this? Just look wrong tho!
There's nothing wrong with them Ian, it's typical.
The needles don't sit centrally in the emulsion tubes at high air velocities.
+1 (It's ok)Cammo wrote:There's nothing wrong with them Ian, it's typical.
Cool, many thanks for the updates, i slam them back together tomorow.
Ian
Ian
- One Hit Wonder
- Bike owned: NC30, Ducati Desmo 250
regarding your misfire check the plugs, I had the same problem at around 7-8k, turned out to be a cracked ceramic on one plug.
Yeah cheers, its in loads a bits so wont hurt to have a look and see.
Thanks.
Ian
Thanks.
Ian
