NC30 Disks and master cyclinder on NC35?
Hi there I have recently done a front end conversion of an NC35 on my NC30, i have a NC30 front wheel
and NC35 wheel spacers, and NC35 calipers however i was wondering if disk on my NC30 wheel would
be ok in the NC35 calipers ok.
Regards lee
Regards lee
Re: NC30 Disks on NC35?
I hope so because that's what I've got!
Actually no, nearly though, I've got an NC35 with NC30 front wheel/discs and CBR600RR calipers, not used them enough to find any problems but they work fantastically.
Druid
Druid
The discs are the same so you will have no worries
Cheers guys any ideas to whether the NC35 master cylinder is the same as the NC30?
Re: NC30 Disks and master cyclinder on NC35?
yep - think so. the whole braking system is pretty much the same
just wanted to check as i didn't know what braided hoses to order.
as i have nc30 ones but the lower banjo doesn't fit due to the shape?
the top of the hoses is the same..but the lower banjo is different as you have found out.
I use a fireblade m/c and used my '30 lines on it til I got my new calipers as the caliper fittings are at different angles.
if you got RVF or blade lines you should be good to go.
excellent cheers for that :D
I thought that they're not actually the same but were identical fitment?CMSMJ1 wrote:The discs are the same so you will have no worries
NC35
NC30
As you can see the NC30 ones are filled with holes, the NC35 ones don't have so many holes.
Could I suppose be after market discs though.
Druid
- monkeywithaplan
- Bike owned: NC35 and NC30
looks standard on each druid, got the same on my 30 and 35, though some egit sprayed the centres on the 30s and now ugly as sin
, more work for me to do :)
