God dam Lights
len5a
God dam Lights
Post by len5a »
Hello friends,
Can anybody help me please, when my bike is on tick over the lights are slightly duller than when riding/reving. I'm sure thats how they should be, but when riding they suddenly get really bright then go back and i'ts doing this all the time.
The difference is 'LIKE' going from dip beam to full beam although this isn't whats happening. I'ts starting to worry me as a car pulled out in front of me 10mins ago.(it was close)
I've checked fuses and bulb connections but they are ok.
Can someone tell me where the earths are?
Has anyone had this sort of problem before?
Thanks, Ian...
Matchlessman
Re: God dam Lights
Post by Matchlessman »
Hi Ian,
It could be your voltage regulator on the way out. Check the voltage on the battery terminals on tickover and then revving the bike. if it goes over about 13 and a half/14 when you rev the bike then it could be dead. - voltages are off the top of my head but i know that if its massively high then its not good! Hopefully someone good on bike electrics will post the more exact mesurements.
Too many bikes, so little time!
len5a
Re: God dam Lights
Post by len5a »
Thanks Matchlessman,
I hope its not. I'm on my third reg/ref in a year. I made sure when i put this one on about 3 months ago, that all the voltages were correct, after the second one i fitted wasn't the correct one for the bike and burnt/melted the connector to it. I'll check it again in the morning to be sure.
Thanks for the reply.
veefer400
Bike owned: Ducati 900SS, 1978 Cafe 400/4
Re: God dam Lights
Post by veefer400 »
Matchlessman wrote:Hi Ian,
Second this - summats not right with your reg/rectifier.... :|
Rover220
Re: God dam Lights
Post by Rover220 »
hold it at 5kish, should see no more than 14.7v and no less than 13.7 ideally.
GF Racing
Re: God dam Lights
Post by GF Racing »
Check you have the correct standard Honda import bulbs fitted (35w dip) and the 2 x main 12V connections on the starter relay are clean / not melted / not corroded.
Hope that helps.
Graeme
Tel 07778 628448
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
AliasOmega
Re: God dam Lights
Post by AliasOmega »
funny enough, i have 2 of these bulbs sat on my kitchen table ready to go the bike part heaven that are unused / wanted.
H4 something..
leopard_pagan
Re: God dam Lights
Post by leopard_pagan »
55/35W cant remember what the H is, but do know its not H4 as i used to cut the tabs off, i can now use H4 with the units modified to take them.
but if you have higher wattage bulbs fitted with out the propper relay mods, you'd loose the dip as the switch innards have melted.
