I'm undergoing a valve clearance check on a new engine before fitting it to my bike, but when the T2 mark is in the right position I cant get the lines on the camshaft to line up properly. I havent taken the cams out on this engine before, but i dont know if a previous owner has, does this mean the timing is out?
Any help greatly appreciated.
NC30 Valves won't reach TDC
Re: NC30 Valves won't reach TDC
One which camshaft is this?
Thanks for your help
lol, no worries. It seems complicated but it actually isn't.
Are you running them closer to tolerance or a touch on the open side?
No, I was just confusing myself, i do valve checks pretty often on various bikes, hence me feeling so stupid
And I was aiming for tolerance, but the shims i need are going to have to be bigger than i had hoped [The clearances were further out than anything I have measured before] so it looks like using the shims i have available will leave them a little on the open side - your comment makes it sound like this could be benificial? I have only ever aimed for tolerance before so I wouldnt know.
I always aimed for .17 rather than .15 on the inlets and the same on the exhausts - .2 loose.
Open is not as bad as too tight IMO. The HRC manual has them at .20 if I remember it right...
You are absolutely right, aiming for the more open end of the tolerances has given me a little more room to play with, and made it much eaisier to find the right clearances - Thanks!
Also i'm presuming the gaps naturally tighten over time but I cant find it mentioned in the manual I dont suppose you could continue to enlighten me please?
