JHA Exhaust
VFR400+
Re: JHA Exhaust
To update slightly, got the quote from the machinest to clean it up, wire wheel/ polish, £150!! So bought a bench grinder and some mop. Will do it myself for a 1/3rd of the price and get to keep the grinder.
viper_biker
Re: JHA Exhaust
JHA pipework cleans up real nice too. Here's the pipes from my old SP-style full system.
VFR400+
Re: JHA Exhaust
Just realised its been a while since I updated, I got a grinding wheel with wire wheel attachment although it was so underpowered. Any pressure applied and the poor thing would die. So took the guard off my angle grinder so I could fit the larger wire wheel on and used that. It shook like hell but worked well.
Got a slight problem sealing the rear headers as they are each only held on with one spring and it doesnt seem to be sealing very well.
- hannakournikova
Re: JHA Exhaust
looks good mate! even better when its all done by yourself.
apply some clear sealant to the pipework for a good seal
VFR400+
Re: JHA Exhaust
Cheers - cheaper too!!hannakournikova wrote:looks good mate! even better when its all done by yourself.
Ive got some RTV (or RVT cant remember) sealant that Ive used on the rest of the joints but wasnt sure about using it where it joins the block as wasnt sure if it would withstand the heat.
Re: JHA Exhaust
I use bathroom silicone. Cheap and works fine.Snark wrote:Cheers - cheaper too!!hannakournikova wrote:looks good mate! even better when its all done by yourself.
apply some clear sealant to the pipework for a good seal![]()
VFR400+
Re: JHA Exhaust
What on the headers where it meets the block? Does it not get far to hot for standard silicone?Neosophist wrote: I use bathroom silicone. Cheap and works fine.
