start up issue or normal???
blackduck
Bike owned: cbr400rrj
Post by blackduck » Sun Sep 04, 2011 3:35 pm
hi guys,
my 400 j model starts on the button every time.......my issue is this, when idling first it clanks slightly and when i rev it just to 2000rpm it goes.....but once warmed up it is normal. i can stop it and start it and it sounds normal when its warml......what could the cause of this be or am i worrying about nothing?
thanks for any imput :rocks:
kiwi racer
Bike owned: CBRs
Re: start up issue or normal???
Post by kiwi racer » Mon Sep 05, 2011 7:36 am
What oil are you using and how old is it ??
What is the idle reading on your rev counter when its making the noise?
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti » Mon Sep 05, 2011 9:18 am
Perhaps the start clutch is getting worn? The rivets holding the halves together get worn and come loose. It's possible to weld it back together if you catch it in time. Next time, try to check if it's a rattly sort of noise coming from the front left engine cover.
blackduck
Post by blackduck » Mon Sep 05, 2011 9:30 am
If it was starter clutch would it stop rattling after a few mins.it starts normal and only rattly when rev first thing up to 2000 rpm them fine. After 3 mins its gone. It kicks going into first its first time but after that it is perfect. More than likely related and have been pricing new states clutch and springs on bitz4bikes last week.
blackduck
Post by blackduck » Mon Sep 05, 2011 9:33 am
Oil is fresh. Idler at 950 rpm fine with no noise. Only when reved up to 2000rpm that it makes the noise. This only happens when cold . Normal running when warm.
gullarm
Post by gullarm » Mon Sep 05, 2011 5:40 pm
Tick over should be 1300 +/- 100?
Mine would conk out at 950rpm.
Try pulling the clutch in when starting to see if that makes and change to the noise.
