MONEY NO OBJECT (If Only) FZR 400?
				sportspromatt
OK, with money no object! what would you build? (NOT THAT IT ISNT< IM ON THE SAME ~LEEKY SHIP AS (EVERYONE) ELSE!
modified or a one of factory fresh original?
- Kayla850
- Bike owned: Sunn Tzar S2
Re: MONEY NO OBJECT (If Only) FZR 400?
It'd be a nice late 3TJ SP with FCRs but with some really nice bits on it, like a Nitron shock and 5 spoke Gucci wheelssportspromatt wrote:OK, with money no object! what would you build? (NOT THAT IT ISNT< IM ON THE SAME ~LEEKY SHIP AS (EVERYONE) ELSE!
www.projection-racing.com
www.pjcfasteners.com
				hunter
I would complete the Hybrid i'm building,
because it's so different,
Things Done.
3tj frame.
foxeye engine.
Micron r6 exhaust.
Translogic Dash.
It's fitted with NC30 swingarm.
VFR750 Rear Wheel.
ZXR400 Forks.
NC30 Front wheel.
320mm Wavey Discs.
gsxr1400 6 pots.
fireblade radial master.
Modified triumph 675 seat unit and subframe.
Things to do.
powdercoat frame-swingarm fork bottoms subframe wheels.
make link pipe and oval can for underseat exhaust.
find suitable fairings not glassfibre but somthing different.
Things Done.
3tj frame.
foxeye engine.
Micron r6 exhaust.
Translogic Dash.
VFR750 Rear Wheel.
ZXR400 Forks.
NC30 Front wheel.
320mm Wavey Discs.
gsxr1400 6 pots.
Things to do.
				hunter
Close,But not quite.
				nick
What i ment was i'd already built the bike I would if money was no objecthunter wrote:Close,But not quite.
 If i could do it again, i'd definitely fit a different front end - usd from a zxr400 or a 636 most likely. Probably change the underseat pipes for a either a single oval like the 675 or go for a MotoGP style stubby just out from the belly pan. Wasn't my money so i built what the guy wanted
- jim157
Probably a 3TJ based YZF400 replica with a pair of Dymags and a sprinkling of titanium and carbon fibre.
AUTOEXEC.TWAT
				barryfzr
Mine with a brand spanking new set of plastics...and a wash ;oD
Have a look at those Chinky fairingsbarryfzr wrote:Mine with a brand spanking new set of plastics...and a wash ;oD
				barryfzr
I've never seen Genesis ones? I planned to get some oem ones when I got the mechanics all there but I think they've stopped making someEvilchicken0 wrote:Have a look at those Chinky fairingsbarryfzr wrote:Mine with a brand spanking new set of plastics...and a wash ;oD
