Weird clicky noise coming from CBR400RR engine
niteblade
Bike owned: NSR150SP, RVF400
Post by niteblade »
my brother bought a cbr400RR recently. it runs well and stuff. but there's a weird clicky noise coming from the engine.
double checked with my dad's super 4 and my NC35. our bikes dont have the sound.
we brought it back to the shop for a check but the mechanic says its just a loose screw and they fixed it. however the noise is still there.
anyone knows what the problem could be?
angry_rob
Re: Weird clicky noise coming from CBR400RR engine
Post by angry_rob »
It could be that the valve clearances need doing, as they progressively get less accurate it makes a bit of a tapety noise, at least that's what I've noticed. Then again I may just be nuts.
leopard_pagan
Post by leopard_pagan »
is it intermittent?
if so its just the fuel pump points you can hear.. nowt to worry about
Matchlessman
Post by Matchlessman »
Is it rev dependent? It could be the start of a hole in the exhaust.
kiwi racer
Bike owned: CBRs
Post by kiwi racer »
Lets face the reality folks , its a noise at issue here and as good as we may think we are a noise can only be diagnosed by hearing it , not by this format.
Matchlessman
True enough but at least we can give him things to look at and check.
adz400
Post by adz400 »
ive had my cbr a couple of monthes now and also have heard a clicking noise. seems to be coming from the carbs. only happens when the fuel is low so the fuel pump theory could be true. although i didnt think they had fuel pumps???.
Davez29
Bike owned: NC29 forever
Post by Davez29 »
one more thing to try although not exactly a clicking noise, pull the clutch in see if its still there. adz400 the cbrs do have a fuel pump for sure.
Matchlessman
If you leave the fuel turned off with the bike running for a couple of minutes and you will hear the fuel pump ticking noise.
Mikiboy
Bike owned: RVF400 NC23 x 2 NC29 CBR4/600
Post by Mikiboy »
I had a CBR4 whuich i changed the engine. That clicked for about 8 months then stopped. I never managed to figure where it was coming from or what caused it.
I changed it as the original one was had it. You could hear a tinkling noise before it let go, though I guess I'd ran it like that for a year or so.
