RVF forks into an NC24??
Re: RVF forks into an NC24??
I need rubber for them, more importantly i need the money to pay for the rubber hah!
In between ordering other bits for the bike i'm a little short of cash at the moment. As soon as its on i'll have a full write up done.
http://www.vsource.org/VFR-RVF_files/NC ... rwheel.htm" onclick="window.open(this.href);return false;
try having a look at that. Your already on a +1 over the 30 as it uses the same mounting hub.
Legend!!
Am I right in reading that as the VFR750 uses the same rear hub as the NC24??
The PCD (bolt hole distance is the same)
From my measurements, a 160 tyre (as opposed to the stock 170) shouldn't hit anything too badly.
It'll be close to, if not touching the link pipe, but should clear the chain.
I'll tell you when I have rubber on it.
oh and fwiw I managed to pick up my rear wheel for £30 which isn't bad :)
Marvellous! I have a Moriwaki link pipe & can so it might be different?? Will have a peek tomoz and see...
Has anyone got a pair of NC24 fork springs so they can measure the diameter for me? May get some spacers knocked up, did try raising the air pressure but didnt seem the work - have now removed it for fear of blowing the seals....
Can't wait for that, if it works without too much trouble im sure i'l be doing it :):)As soon as its on i'll have a full write up done.
No problemo!
It's something i'm actually looking forward to doing too! It's so difficult to find information for NC24, even in Japan!
I am making my website too to try and document everything, there doesn't appear to even be any microfiche on the internet.
I've got these to scan in as well as the service book which should be of some use to 21 / 24 owners
I have the 'hrc performance' book for the NC21 (in Japanese), I'll try and get a copy scanned in the next week or so.Neosophist wrote: I've got these to scan in as well as the service book which should be of some use to 21 / 24 owners
For what it's worth, it states the F3 NC21 puts out over 72hp!
I also have the '21 & '24 hrc F3 manuals coming in the next month. :)
Oh cool, get them scanned in :)
That wouldn't surprise me, the F3 stuff is quick, i'm sure somone on here has an NSR F3?
