a short list for help or advice?
First when put bike into gear it basically jumps abit also a big clonk then when riding and changing gear's still makes annoying clonking noise now is this the norm as doing my head in ? this is what I have done (1/checked oil (2/had chain adjusted also to add to that i have to rev bike up just to get into neutral.
Second question looking around bike noticed bottom shocker bracket has been hitting top off exhaust pipe sorry don't know the technical saying for bracket any 1 had same problem's and resolved these could point me in right direction would be great help
Re: a short list for help or advice?
Your clutch might need adjusting slightly. They all need a little blip to get into neutral too..so that is no worries.
Sounds like your clutch is dragging - so slacken it off a touch.
Is it a standard shock and a standard exhaust? It would only hit it at full extension so not a problem unless you are doing jumps!
will try slack clutch off abit would that cors it to clonk when letting go of throttle?
changing down gears sounds as if not using clutch at all
as can see the every thing is standerd on bike
just bit worried about it mainly when having passenger's on bike cheer's for help m8
