nc35 fork damper bolt spinning?
- skinnydog0_0
- Bike owned: Penny Farthing
Hi all,
Has anyone ever had this problem of teh fork damper bolt spinning in the bottom of the fork?
The first fork went fine no problems, but this on it undid about 1/2 turn then stopped all the oil started dripping out and the cartridge just spins.
Is there a way i can hold the bottom of the cartridge?
I have taken the fork to the local bike shop and asked them to use the airgun on it and still no joy
Any advice much appreciated.
- Bike owned: ftr223 650 bros
Re: nc35 fork damper bolt spinning?
With the fork assembled and pressure applied to compress the spring and load the damper, the bolt may undo.
If not, look at the removed damper unit from the other fork leg.
You will see 2 slots that can be engaged either with a bar or even make up a 2 peg spanner to fit.
Dave
Dave
- skinnydog0_0
Hi Dave,
The other fork is back in the bike now, so cant see the other unit. I think i am going to go to teh plumbing centre and get some steel tube and make a slotted socket (after the moto gp)
Before you do that, try to hold it with a lenght of flat bar, I used 25mm x 8mm,
Dave.
Dave.
- skinnydog0_0
Hi Dave, very good idea, i will see what i have in the garage but i dont have too much in the way of metal knocking about. Might have to cut some off the wifes car
Then try 1" x 1" wood first, sharpened to a V.
Dave.
Dave.
I used a long metal rule, worked a treat
- skinnydog0_0
I have cut slots into a piece of tube and can hold the bottom part of the cartridge but the bolt is still spinning
am i missing something?
Sounds like the nut is turning within the damper, how far is it undone?.
Its a round nut, located with a staking/punched locator to stop it turning.
Depending if thread lock was used, and what strenght, try loading the nut with the damper.
Either lever the damper up, or if room, lever under the allen bolt head to maintain pressure between the nut and damper inner housing, whilst slowly turning the bolt.
It will be more luck than anything,
Dave.
Dave.
- skinnydog0_0
Yer i think the thread has rounded as it is only a fraction out and spinning or the valve is spinning inside the cartridge. I have tapped some lengths of hacksaw blade between the cap head and fork to stop the bolt spinning and am gently drilling the head off. I can then use a stud extractor to get the rest of the thread out of the valve once i have the cartridge free.
