valve clearances idiot question 3
oldgreyandslow
- Bike owned: 1990 NC30
I've taken the shims out of cylinder 4 to measure them as the clearances here are well off, but will have to rotate the crank to measure cylinder 2.
Is it OK to do this without any shims in number 4?
Probably a dat question, but I just want to check
Ta
Ta
Re: valve clearances idiot question 3
Dont' do this.
While it might not cause too much harm you run the risk of the valve popping out as the shims stop the valve from being pushed out.
I create a diagram for each cylinder.
(EL)(ER)--(EL)(ER)
(IL)(IR)--(IL)(IR)
(EL)(ER)--(EL)(ER)
(IL)(IR)--(IL)(IR)
Firstly measure all the shims and write in their thickness.
Then measure all the clearnaces and write these below.
You can then work out your new shim thickness.
If the gap is 0.5 but your range is 0.15-0.20 and your shim or ex was 2.95, you'd need a 2.85 shim to get to 0.15 (shims come in gaps of 0.5)
Once you've measured all the cleanres / shims and worked out what you need you often find you can swap some around...
Make notes of what shims are in what valve then next time you only need to measure clearnaces and refer to diagram
(EL)(ER)--(EL)(ER)
(IL)(IR)--(IL)(IR)
(EL)(ER)--(EL)(ER)
(IL)(IR)--(IL)(IR)
oldgreyandslow
really, so I have to measure the old shims and put them back in before moving on to the next cylinder then?
ffs this is a bloody nightmare
It is alright..you'll get the hang of it by the time you finish!!
Most people seem to drop a shim in the motor, so avoid it...taking the sump off is ballache.
Neo is great for his instructions so you cannot go too far wrong with his advice (apart from his lack of V4 bias..)
oldgreyandslow
I am really strtuggling to fit the shims back, tweezers, dont do it, the shim doesn't seem to stick with a blob of grease, ffs at this rate I'd be better off calling in a mobile mechanic
what grease you using?oldgreyandslow wrote:I am really strtuggling to fit the shims back, tweezers, dont do it, the shim doesn't seem to stick with a blob of grease, ffs at this rate I'd be better off calling in a mobile mechanic
Some of them I use a small flat screwdriver which I slightly magentised also a blob of grease too.
It sticks, I slide the rocker across out the way and then hold the shim down as I slide the rocker back..
oldgreyandslow
molyporndoguk wrote:what grease you using?oldgreyandslow wrote:I am really strtuggling to fit the shims back, tweezers, dont do it, the shim doesn't seem to stick with a blob of grease, ffs at this rate I'd be better off calling in a mobile mechanic
CMSMJ1 wrote:Some of them I use a small flat screwdriver which I slightly magentised also a blob of grease too.
dont see why your strugling mate
no one else has a problem?
oldgreyandslow
"dont see why your strugling mate
no one else has a problem?"
Incompetence probably
