petrol resistant gasket sealer?
oldgreyandslow
Bike owned: 1990 NC30
Post by oldgreyandslow »
On the carb jetting guide Cammo recommends petrol resistant gasket goo as opposed to new gaskets, I've googled it and looked in my local autofactors, none seem to be suitable for being "totally immersed in gasoline"
Any recommendations please?
porndoguk
Re: petrol resistant gasket sealer?
Post by porndoguk »
Hadies
Post by Hadies »
:plus: I used this stuff for my float bowls.
The Novice
Bike owned: NC23 NC30 CRM250
Post by The Novice »
:plus: Hylomar blue
however be careful applying it as if you put too much it 'squishes' out and can go into the bowl and could potentially block a jet.............. :whistle:
dont ask me how i know that. :oops:
Cammo
Post by Cammo »
oldgreyandslow wrote:On the carb jetting guide Cammo recommends petrol resistant gasket goo as opposed to new gaskets
That was before I discovered Rick O's replacement o-rings for float chamber gaskets (the genuine gasket kits are expensive!). It's covered in the thread but not in the pdf version of the guide.
The o-rings are a much better option than gasket goo. :peace:
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Post by hardnutdvd »
you cant even get the chamber gaskets individually for the NC35 :(
you have to buy the whole gasket kit if you want them
The Novice
thats the same for the nc23, however i was told (by cammo i think) the Rick O replacement o rings for the nc30 would fit - and he was right ! cracking tip... and saved me forking out for 4 gasket kits, which gets v expensive. not sure if they would fit the nc35
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
I am told 3 Bond is best for petrol sealing, but also soaking O rings in boiling water for a few minutes swells them to original size, but have not tried it yet.
dave.
hardnutdvd
Regular Member
longmoreuk wrote:thats the same for the nc23, however i was told (by cammo i think) the Rick O replacement o rings for the nc30 would fit - and he was right ! cracking tip... and saved me forking out for 4 gasket kits, which gets v expensive. not sure if they would fit the nc35
nah, it was Rick that told me the chamber gaskets aint sold individually and only available in the full gaskets kits.. when i tried ordering some from him a while back
