Is it poss to firm up front forks
- Bike owned: 2008 R6 Race Bike
Re: Is it poss to firm up front forks
My bike has 12.5 weight fork oil, but it's old and sad and ugly! It needs fresh oil, but my bike is in Victoria and I'm currently living in Tasmania. I'd say I'm now at the level where I would notice things like oil weight, but being unemployed and an hour's flight away, I can't do any experimentation on it.CMSMJ1 wrote:Cool - I never knew that the 29s were all damper rod forks. It makes total sense that seperating the high/low functions of compression would make it miles better. Do you have any thoughts on how the rebound is afected? Do you run a different weight oil with this set-up?
I don't believe rebound is changed from standard (it's certainly not controlled by the emulator), so there is no adjustment there. I've not found the need to adjust rebound, but that's most likely because I'm not going fast enough. I was doing 1.53's and a 1.52 at Phillip Island a couple of weeks ago (until I dropped a valve), the guys at the front were doing 1.50's to 1.48's
Back to the NC23, my mate has a stock front, and with that is capable of 1.47's at the Island. He reckons he's heard that Graeme France does a Gold Valve for the 23, so might be worth talking to him.
Only R-model NC29 has cartridge forks.
lol - stop confusing the matter!
- Bike owned: CB-1, MSX125
Quite.CMSMJ1 wrote:lol - stop confusing the matter!
The first thing to do is change the springs and new oil. After that you can see if the damping isn't good enough.
Springs and new oil, I understand!! I might drop Graeme France a quick email to see what he reckons and if he supplies any springs that would do me, otherwise the wemoto ones will do the trick. Thanks everyone for the info and advice.
- Bike owned: CBR400RR NC29
I emailed Graeme France recently about this & the reply I got was:
Upgraded GF Racing front fork kit comprising new linear springs / oil / fork seals / aluminium spacer tube and the all important set up data - £128
Or fully recon upgraded front forks built by me with parts as above - 228 pounds exchange.
New Adjustable Gold Compression Emulator Valves also available for that ultimate front end set up - £145
Please advise rider weight at time of ordering / and road / track / mixed use.
UK postcode delivery - £12
Worldwide delivery is fine - please advise location
All as used on our Championship winning Street and Formula Class NC29s.
Graeme has the skills.
My NC30 forks on the race bike were setup and sorted by Graeme (for the previous fork owner) and are superb - heavier springs and fresh oil does the trick
