Oil Leak
David
- Bike owned: VFR400 NC24
Re: Oil Leak
Ok,
Managed to get seal ot eventually, tried all sorts of make shift tools (should have bought a seal puller)
Had to give it a whack to get it to move - seal is metal covered in rubber.
I damaged part of the seat at the back but there is enough left to seat a new seal.
I found a spring thingy in there(see photo) - any ideas where this should be and my clutch push rod is in 2 parts as can bee seen in photos
This is the pushrod end I pulled out first - has an insert where the other long bit fits in to
This is the pushrod end together with mangled seal and the unknown little spring thingy This a larger pic of the unkown spring bit If you look carefully you can see the seat at the back with gaps where I broke this, I have cleaned it out, need to get a seal ordered but need to know what the little sping bit is before I do anything else.
Any ideas on this and a part no for this seal?
hunter
Re: Oil Leak
The spring is part of the seal,When you get your new one take a look on the inside lip of the seal you will see your spring.
David
Re: Oil Leak
OK thanks.
I have contacted David Silverspares and they have come back with the part no
91204KE8003
which is described as - OIL SEAL,13X22X5 *B
Now as far as I know this means 13mm ID, 22mm OD and 5mm thick
But having just measured the clutch push rod it is 8mm diameter, so 13mm is a bit big
the 22mm looks about right and it is about 7 or 8mm thick
Does anyone know the definite part no for this seal before I order the wrong sizes
91204KE8003
Dynamohum
Re: Oil Leak
would confirm with silvers that its the clutch pushrod seal your getting and not the gearchange shaft oil seal ?
David
Re: Oil Leak
Ok,
Measured push rod and space where it will go and ordered 2 of these at David Silver Spares
91204-MB0-013
Oil Seal 8x25x8 is the correct size for those who need to do this.
I had been given a couple of different sizes as suggestions, but finally measured (should have done this first).
Fitted last night. Used a socket form my socket set with similar diameter on the extension rod and tapped in gently with a rubber mallet. Started bike and no oil leaks - fits perfectly.
Thanks all for help
91204-MB0-013
Thanks all for help
hunter
Re: Oil Leak
Good to see your sorted.
