rvf fairing on a vfr
sheepus7
- Bike owned: VFR 400
is it a staight swap to put nc35 fairings on a nc30
thanks
sean
thanks
sean
dave6970
- Bike owned: SP-1, NC30
Re: rvf fairing on a vfr
Not 100% sure but I think the fairing fixing bolt is lower on the RVF
sheepus7
ok thanksdave6970 wrote:Not 100% sure but I think the fairing fixing bolt is lower on the RVF
- CRM
lowers are the same item essentially, nose mounts different as do the mids.
so you could use 35 lowers on a 30 but changing the whole lot is not a simple bolt on onto the 30 bracket on the front.
seat panels are different too and would require a 35 subframe to fit.
sheepus7
ok thanks for the helpCRM wrote:lowers are the same item essentially, nose mounts different as do the mids.
p.s. where abouts in cheshire are you from
- CRM
sheepus7
not far from me thenCRM wrote:Between chester and runcorn
