Yet another nightmare any ideas?
Scarth
- Bike owned: Daytona 675,Husaberg,Track Nc
Front brake discs
Ebc pro lite front discs
Took the front wheel off the nc to find one of the front discs is quite loose the the middle part that's gold.
I know they are floating put you can really moove these with your hand
Can you tighten the rivet thing up slightly or what?
It even rattles slightly on the bike
Or is it just a new disc job..?
Re: Yet another nightmare any ideas?
i think you can get new rivets but youll need them fitting at a bike shop as its a speciallist tool, but for what its worth based on them wearing its better to get new discs.Scarth wrote:Front brake discs
have you measured them?
- hannakournikova
my race EBC (blue centre) rattle like a tractor! apparently their meant to!?
They are supposed to move side to side, not front to back.
If they do, replace the bobbins. (EBC supply race discs with a set of bobbins to replace the first set when they wear)
The rattling sounds normal.. especially if there more race orientated discs.
They are there for expansion, as the disc gets hot and expands it fills the gap and they stop rattling.. otherwise the disc would warp (bend)
I could move my ZXR ones left and right with my hands.. there not supposed to move forwards and backwards tho.. this means the rivits wearing out
rcv4
its usually the center that wears out,i have seen a pro lite were the rivetts had nearly worn through the center.
Glad I just use Honda discs.. not needed or come across anything i'd consider 'better'
