Revs bouncing around
The Novice
Bike owned: NC23 NC30 CRM250
Post by The Novice »
I think the tacho on my bike is either faulty or wiring is broken/loose connection as the revs dont pick up on the tacho properly. Anyone know where does the tacho get its info from so i can trace where there might be a loose connection.
Cammo
Re: Revs bouncing around
Post by Cammo »
It's usually to do with a loose earth wire.
Check that the earth (negative) wire at the back of the tacho is attached firmly, maybe take a look at all other earths on the bike also.
The tacho signal comes from the cdi, usually via a coil.
The Novice
will do , thanks for the info.
