NC30 and 35 rear spindles
Are the wheel spindles for the nc30 and nc35 the same? I bought an NC35 one of ebay and it seems to be a bigger diameter than the hole in the hub. If it is different then it has made my mind up on one of the mods to try on the back end.
Re: NC30 and 35 rear spindles
splines farked
- Bike owned: CB-1, MSX125
So what you're saying is you have no way to actually be 100% certain that it's not from a VFR750, 800 or a Ducati?MartinArcher wrote:Are the wheel spindles for the nc30 and nc35 the same? I bought an NC35 one of ebay and it seems to be a bigger diameter than the hole in the hub. If it is different then it has made my mind up on one of the mods to try on the back end.
I have looked at the splines and they look ok.
I have no way of knowing if it is correct as everything I have bought off ebay and maybe it is the hub that is wrong? The spindle does look like an RVF one with the nuts and spacers that came with it, but I have decided to do away with it and make a nut to screw into the hub. Job jobbed as they say.
