SP engine pick up
				dobbslc
SP engine pick up
Can anyone tell me what I need to do to get an SP engine to work in a standard bike?
						- 4hundread
- Bike owned: 91 GSXR 400
Re: SP engine pick up
V
				dobbslc
Nice on e I'll have a look later, maybe this one will work......
				stripes1976
- Bike owned: 6 gk76a's, nc29
if its a road bike run it on non sp carbs and you will have better bottom end and mid range than a std sp.
It makes for a better road bike than a standard sp then
- 4hundread
K
				dobbslc
   Got the engine fired up today,
  Got the engine fired up today, Battery, Fuel, choke, press button and it runs!!!! I can't believe that this thing has sat for two years and started that easily. Right into the gararge to do the swap ,lets hope this works.
- 4hundread
U
				dobbslc
Are the sp carbs bigger than standard ones? & will I need to swap the carb rubbers to match?
				stripes1976
sp carbs are 35mm not 33mm on the non sp.
unless you have the sp airbox, loom and cdi stick with the 33mm carbs and inlet rubbers.
