how much forks oil per leg 3TJ model forks?
Re: how much forks oil per leg 3TJ model forks?
Great if your setting up a bike for the Japanese home market but these bikes are undersprung. If you want something that doesn't bounce like a space hopper you might want to follow the forum's advice ...csofos wrote:Well, according to my yamaha 3tj service manual the quantity of the fork oil is 433cc (15,2Imp. oz, 14,6 US oz).tiptop wrote:As title says anyone no how much fork oil 2 put in each fork when fully drained?
cheers.
Also, the oil level (from the top of inner tube compressed without spring) must be 106mm (4,17in)
And just to know, the minimun free spring length is 364mm (13,9in).
csofos
Yes man, you are absolutely right! These are for the sp version. What you wrote above are the right ones. I just checked it out.oollit wrote:^^^ Those are the specifications for the SP model which has different forks (Adjustable) from the RR model.
- Motorcycle Solutions
- Bike owned: Kawasaki ZX9R E1
3tj rr forks non adjustable is 450cc just a little more than the sp
