R6 shock
spongy.bob
R6 shock
Post by spongy.bob »
Hi all,
I've been offered an R6 shock and I'm considering fitting it to my nc30.
Has anyone done this already? Or is there a thread on here already? :pray:
I'm particularly interested in the shock length compaired to the OEM shock, and what's involved in getting it on (so to speak)?
Cheers to everyone for any help!
:rocks:
slowsport
Bike owned: NC35
Re: R6 shock
Post by slowsport »
I've done this in the past. The eye at the top needs to be filed down a few mm to fit, and the one i had the reservior did clear the undertray, but the ride height was VERY low!
But i have noticed recently a member called kayla850 that does a custom shock adaptor that might bring up the height
viewtopic.php?f=64&t=19447
spongy.bob
Re: R6 shock
Cheers Slowsport!!
when you say it needed filing down, was that because the diameter was too small, or because the it was too wide to fit in the frame? (if that makes sense)?
hunter
Re: R6 shock
Post by hunter »
slowsport wrote:I've done this in the past. The eye at the top needs to be filed down a few mm to fit, and the one i had the reservior did clear the undertray, but the ride height was VERY low!
Yes but that conversion is for the FZR,Not the VFR.
spongy.bob
Re: R6 shock
Just done a bit of research and the R6 shock is 340mm, where as the nc30 OEM is 305mm. I might be being simple here but wouldn't that make the ride height very tall? or has it got to do with the linkage?
Rob.
Re: R6 shock
it is too tall and won't work mate.
spongy.bob
Re: R6 shock
ye, about 5 inches of extra ride height is a fair bit really! :P
More research and it seems they can also be between 300 and 305mm depending upon the year so that might account for low ride height Slowsport?
Would anyone recommend drilling the dogbone to make its shorter, or is Ricks jack up kit the only real option?
hunter
Re: R6 shock
Post by hunter »
Yes you can drill them,or make a pair like i have.
spongy.bob
Re: R6 shock
oooh, very nice! when you said you made it, i'm guessing you bought two rose joints and then fitted them to a threaded bar?
hunter
Re: R6 shock
Post by hunter »
Well not quite,A mate of mine gave me the rose joints, and i put a thread in some alloy rod.
