fork seals
fork seals
could someone advise me of the oil that goes in the front forks as i have a leaky seal which needs replacing,,,,many thanks in advance
- Yakama
Re: fork seals
Haynes says 10W
Re: fork seals
15w is a common upgrade.
Re: fork seals
how much oil is required?
- Davez29
- Bike owned: NC29 forever
Re: fork seals
According to Haynes, depending on model its..cokidoke wrote:how much oil is required?
oil capacity
J & K (nc23) 490cc
L & N (nc29) 453cc
R (nc29) 408cc
Air gap is
J & K (nc23) 96mm
L & N (nc29) 105mm
R (nc29) 120mm
Basicly buy a litre and you will have enough. You can just change it with forks in place but my opinion is that your better taking each leg off and refilling to get the correct air gap, which means compressing the fork to its smallest limit.
