Installing speedo cable - NC30
Hi All,
first time posting (excluding the introduction board)
I fitted a new speedo cable on my nc30, and initial tests (on driveway) appeared successful. A day later and no luck, no readings on the speedo!
I have since tried reinstalling the cable, but without success. Rotating the drive end of the cable manually does indicate a speedo reading. It's hard to tell if the cable is aligned with the drive tab... any tips would be much appreciated.
tom.
tom.
Re: Installing speedo cable - NC30
Howdo, welcome!
How did you test it on the driveway? Up on stands?
Have you 100% confirmed it is the cable? Is your old cable snapped?
Might be the nylon drive wheel on the front sprocket - whip the cover off and check it out.
If it is knackered you can prob get another for a few quid or a chap on here made a few allloy ones..he might make some more
Cheers, will give it a try.
I say the driveway... car park of my block, so was running it up and down (being a general nuisance). Strange though that it was working fine, parked up then the following day I get nothing.
anyway, all good fun getting to know the new bike :)
tom.
tom.
