Which Rectifier
amorti
Regular Member
Bike owned: CB-1, MSX125
Re: Which Rectifier
Post by amorti » Thu Apr 28, 2011 5:14 pm
jamie wrote:Hi Domski1
There are 3 wires going in from generator and 2 wires going out to battery.
Its deffinatly the reg though, i have tested the output terminals and there is no voltage there
Have you tested the alternator output? People tend to get target fixation when it comes to electrical problems on nc's: "oh, it's not charging, must be the regulator" when actually it could also be the alternator.
jamie
Re: Which Rectifier
Post by jamie » Thu Apr 28, 2011 8:45 pm
Thanks Amorti
All 3 phases of the alternator are generating voltage and the resistance between the windings is ok,
I got a new reg rec and new battery coming saturday so hopefully everything should run fine :pray:
