A N Other 3TJ 4/6 in the offing
Re: A N Other 3TJ 4/6 in the offing
Ah i see. 50mm thats quite a bit, is the R6 shock shorter than the FZR then?
Bloody nice idea, how much ride height does it give you over stock?
- Kayla850
- Bike owned: Sunn Tzar S2
The R6 shock is 50mm shorter than the 3TJ shock and the adapters can give more or less ride height, depending on where the holes are drilled. I generally send them out to give standard ride height but others have asked for longer to give slightly more ride height.
www.projection-racing.com
www.pjcfasteners.com
				hawksuspension
- Bike owned: 3tjrrsp/NC29/998R/rc30 750 rep
Looking very nice..Diggin the front headlight mod  ..
				Bikemike
Hi Kayla,
Did I see somewhere else that you are selling this?
Please tell me it isn't true!
Mike
Mike
- Kayla850
Hi Mike,Bikemike wrote:Hi Kayla,
Mike
I was thinking about it, but I've ridden it a bit more, changed the oil, balanced the carbs, sorted the fuelling and am starting to love it- it's bloody quick! Paint next
				hawksuspension
Good StuffKayla850 wrote:Hi Mike,Bikemike wrote:Hi Kayla,
Mike
 All that work be a shame to shift on
  All that work be a shame to shift on-
The more you ride it the better it gets
						- Kayla850
Too right! We went out today for quiet potter- Stokesley > Helsmley > Pickering > Whitby (for chips!) > Home. The road from Pickering to Whitby is the awesomest road everEvilchicken0 wrote:The more you ride it the better it gets
It didn't miss a beat, which is nice.
				StreetFZR
- Bike owned: 3TJ 4/6 TURBO Streetfighter.
Thats very near where I live!Kayla850 wrote:Too right! We went out today for quiet potter- Stokesley > Helsmley > Pickering > Whitby (for chips!) > Home. The road from Pickering to Whitby is the awesomest road everEvilchicken0 wrote:The more you ride it the better it gets
Where abouts are you from??
I am doing a 4/6 build starting in october time and would be great to know somebody local enough who done it before.
				4StrokePete
- Bike owned: FZR400RR SP
Hi Kayla,
I'm trying to finish off a 4/6. Pretty much the same as yours, 3TJ with 4JH engine.
I'm interested in what way you went with the airbox ? Did you mod the 3TJ to fit ?
Mine will be a track/race bike only.
Cheers Pete
Cheers Pete
