Rear lower engine bolt removal?
wassy123
Post by wassy123 »
Anyone got any tips on how to remove this? I cant get it off!
Its the bolt that goes right the way through! Its like an allen key in centre with 2 raised flat sides next to it!
Would be much appreciated!
Cheers. Wassy x
porndoguk
Re: Rear lower engine bolt removal?
Post by porndoguk »
You need to undo the castlelated nut on the O/S - RHS first buddy. read the haynes it explains what you have to do.
wassy123
Post by wassy123 »
Yeh iv undone the normal nut on LHS and the castleated nut on RHS but then there is the centre bit with the Allen key in centre?
porndoguk
Post by porndoguk »
maybe this image maybe able to help how the mount is positioned etc
it really isnt a difficult job, you just need support under the engine, and take the presure of the mount/bolt.
as for the cable to emailed me about, contact rick oliver, or just re crimp the cables after choping the plug off the alternator.
wassy123
Post by wassy123 »
Yeh thanks bud, ill give it another go. Whack some rust penetrating oil in there!
Ah right got all that stuff in work, thought there might have been a way to get it out :(
Cheers.
