dobble check
spud
Bike owned: vfr nc30 1990 , yamaha rs 100
dobble check
Post by spud »
hi all
just thought i would kill two birds with one stone , as im new to the forum but my name is sam and im from norwich and picked my first nc30 , 1990, up the other week which im well happy with 8-)
but over the weekend i thought i would check the valve clearance , and found that i will need to change around 12 of my shims ,
ive worked out what shims i need but was wondering if the method i used was correct , here is the way i worked them out ,
just for example
valve clearance was 0.07 when it needs to be around 0.24 , and the shim was 2.22 , so am i right to think i would need a shim of 2.05 , to then have a clearance of 0.24 ;)
and who / were is the best place to get the shims from
many thanks sam
BillingCBR
Re: dobble check
Post by BillingCBR »
Best place to get them is Rick Oliver, he's very close to Norwich and is a top bloke, should be able to help you out :)
jim157
Admin NWAA
Admin NWAA
Bike owned: A few small ones
Re: dobble check
Post by jim157 »
Yeah, we're lucky to have a guru like Rick living in this area.
Here's his contact details:-
Tel - 01603 720387 (5:00 – 9:00 pm)
Email – RickNC30@gmail.com
AUTOEXEC.TWAT
Re: dobble check
Post by Neosophist »
Nice guide here
http://www.hondarvf.com/workshop/checki ... clearances
And yep that is correct.
If your gap is too small you need a thinner shim.
The shim wouldnt be 2.22 though as they go in up .5 so it would have been a 2.25 or a 2.20 depending on your caliper.
Shims also do wear buy very marginally.
spud
Re: dobble check
Post by spud »
cheers guys for the info and help , and that link for the guide to valve clearance will help alot ,
and i phoned rick today / super nice chap / and he pointed out that i had measured the valve gaps with a metric filler and not a imperial ones , so off i go again to remeasure them all again , all good fun :lol:
but thanks again guys cheers sam :rocks:
