Bearing puller as Rotor puller?
davedrave
I have this in the shed, reckon I could use it as a rotor puller to save me getting the fancy bolt?
cheers
cheers
Re: Bearing puller as Rotor puller?
Yeah that looks like it would probably work.
Nothing fancy needed, just an M20 x 1.5 in about the shortest length you can find.davedrave wrote:save me getting the fancy bolt?
- skinnydog0_0
- Bike owned: Penny Farthing
Cammo wrote:Yeah that looks like it would probably work.
I have tried a similar tool to the one you have shown and couldn't get the arms between the rotor and casing and the bolts are cheap enough £5 from Rick O i think.
Dont use that.. it might not fit between the rotor casing.
If you file it down it might fit through the holes but it tends to buggar up the rotor as there quite soft.
You only need an M20 x 1.5mm bolt.. screw it into the hole and it pops out.
There about 1.00 :)
There about 1.00 :)
- STYLER
I recently got one from Rick Oliver along with some other stuff to do my GSXR conversion after ive got me bike back on the road and MOT'd. Its a big ass hex head bolt!!
R.O Stock List part:
NC30/35 Alternator rotor puller (bolt type M20x1.5) £5
