Nightmare! Rear calliper bracket tight up to disc NC30
Scarth
- Bike owned: Daytona 675,Husaberg,Track Nc
Hello guys having a nightmare today,
The rear brake caliper is bolted on the calliper bracket on the rear hub of my nc30 but the alloy half of the calliper that bolts to the calliper bracket is hard up against the disc!
So the discs doesn't run central through the middle of calliper.
Really looks like it's all fastened together right but maybe the calliper wants spacing out from the bracket to centralize the disc in it?
Really don't know need any ideas
Re: Nightmare! Rear calliper bracket tight up to disc NC30
is the brake caliper holder on the right way?Scarth wrote:Hello guys having a nightmare today,
this bit (part 6) which is held on by the circlip?
http://akhara.com/nc30/nc30parts/files/031.gif
Scarth
OMG! Could have been nasty just sorted the problem,
The rear hub nut in the middle of the sprocket was loose! So the wheel and disc etc were all working there way out to the right only the calliper holding them on! Oops
