Bike no low end?
trademe900
Bike owned: Everything 90's
Re: Bike no low end?
Post by trademe900 »
@Cammo- I mean when the water temperature gauge is on the colder side, or when the bike hasn't been running for a while. The bike is pretty much just perfect when cold, the 5k spot isn't there and the 3k one is a lot better.
@Hardnutdvd- when you get it apart you'll see the float has a little metal tab on the hinge that presses against a plunger when the float goes in. You just bend that tab to adjust it. The measurement is from the highest point of the float to the base of the metal carb bowl 'gasket surface' . You tilt the carbs to the point where the float flops over onto the plunger. Don't let it compress down the plunger with the weight, just get it to that point where it flops over onto it and hold that position while you measure. At least that's how I understand it, and the change has worked for me. You are supposed to use a calliper but I just used a metal ruler and my eyes.
It's best just to get stuck in there, I didn't have a clue before I actually saw it with my eyes.
trademe900
Just for future reference, I fixed this one. It was a case of adjusting too many things at once and not being able to keep track of the changes.
I added a stock snorkel which really does have an effect, replaced the airfilter with a foam one and back with the stock 0.5mm washer in place the flat spot is basically unnoticeable, runs good! Just need to fine tune the pilot jet now for idle and under 3k.
I tried it with 1.5mm of washers but it was making it worse as it got more rich.
Oh, how does everyone adjust the pilot screws with the carbs on the bike?
skinnydog0_0
Bike owned: Penny Farthing
Post by skinnydog0_0 »
I use the 90deg screwdriver on the other products page on this site;
http://www.carbtune.com/
I have found this invaluable ;)
