Fastenings for bar end wieghts???
domski1
- Bike owned: Rvf nc35
I have recently bought a new toy for summer, a 1995 nc35 which is a little rough around the edges, there is currently no ends weights on the bars and i have looked down the handle bars and there is no thread to screw the weight into? any ideas would be apreciated, thanks.
dgunthor
Re: Fastenings for bar end wieghts???
IIRC the bar end comes with a wedge (with threaded hole in it) that fits inside the bar, as you tighten the bar end the screw pulls the wedge towards the end of the bar and holds the bar end in place.
domski1
Ah I see, it's just I have been looking at bar ends on the dreaded eBay and it just shows the actual end and the long screw.
amorti
- Bike owned: CB-1, MSX125
That sounds like a "quill" fitting on an old-school bicycle handlebar.dgunthor wrote:IIRC the bar end comes with a wedge (with threaded hole in it) that fits inside the bar, as you tighten the bar end the screw pulls the wedge towards the end of the bar and holds the bar end in place.
Are they so different from nc29 then?
Here's a broken one for comparison.
viewtopic.php?f=28&t=25561
dgunthor
amorti wrote:That sounds like a "quill" fitting on an old-school bicycle handlebar.dgunthor wrote:IIRC the bar end comes with a wedge (with threaded hole in it) that fits inside the bar, as you tighten the bar end the screw pulls the wedge towards the end of the bar and holds the bar end in place.
Maybe I'm confusing my pushbikes and motorbikes - I'll check my RVF in the morning, see what's there...
duncan
The wedge and the screw is how bar-end mirrors are usually fitted
domski1
Just had a look at your thread and the picture of the fitting, where did you get the new fittings from as second hand would be rather hard to come by if they are so hard to get out?
amorti
That was from aaages ago. ISTR I just bought a new bar or had a spare.domski1 wrote:amorti wrote:That sounds like a "quill" fitting on an old-school bicycle handlebar.dgunthor wrote:IIRC the bar end comes with a wedge (with threaded hole in it) that fits inside the bar, as you tighten the bar end the screw pulls the wedge towards the end of the bar and holds the bar end in place.
