NC23 some questions from a novice!
Addsclayton
Hi
Sorry if these are stupid questions but only got my bike on Monday and it's my first one!
Ok first thing the front brakes are binding a little bit, I have taken the calipers off and found that on the left side the pin that holds the pads in is bent, and I was wondering if anybody knew where I could get a new one, also I found that the brake lever (I believe after Market) is always in contact with the servo, could this be causing the brakes to be on a little all the time.
Next could someone please tell me where the fuse panel is and how you access it, I have found the master fuse but can't seem to find the rest (my logic that they are all in the same place seems to have failed me).
Lastly can anybody recommend a good place for spares.
Thanks very much
Adam
Thanks very much
Adam
Wozza
Re: NC23 some questions from a novice!
Fuses should be in a little black box attached to the front left inside of the top fairing.
For all spares contact Graeme France at gfracingtw@live.co.uk
