starter clutch
				Carter
starter clutch
well, i've got the 400 running at long last! only thing is the starter clutch is slipping and i can only bump it off, don't suppose any one know where i can get the kit from?
				joe 90
Re: starter clutch
try
http://www.cmsnl.com/suzuki-gsf400-1991 ... IG-08.html" onclick="window.open(this.href);return false;
they list one for the bandit
ill check the part numbers as they might be the same for the gk76
if yours is a 73 i dont know if theyll fit
				M1KE
Re: starter clutch
73 is the same engine as the bandit 76 isnt technically the same although some parts are common.
				Carter
Re: starter clutch
mine's a 76, so these should fit then??joe 90 wrote:try
				Carter
Re: starter clutch
well.....ordered so I'm about to find out  :D
				gsxr400 racer
Re: starter clutch
your good
						 dunno
 dunno
