Starter relay ?? problems
mikey65
- Bike owned: 2012 Fireblade HRC NC30 K 1989
Hi guys week 2 got the bike out on friday gave it a runn to see if we have any more problems. The bike started and run really well . Gone to start it today and the I heard a buzzing noise it is coming from the starter relay. I have checked all the contections and the fuse and they are ok is it a faulty Relay???
mikey65
Re: Starter relay ?? problems
Hi just checked the battery and have 10.49Volts is this ok???
hardnutdvd
- Bike owned: RVF400 NC35
you mean it wont start now and all its doing is buzzing at the relay?mikey65 wrote:Hi guys week 2 got the bike out on friday gave it a runn to see if we have any more problems. The bike started and run really well . Gone to start it today and the I heard a buzzing noise it is coming from the starter relay. I have checked all the contections and the fuse and they are ok is it a faulty Relay???
the voltage is too low...it should be more than that before the engine is even started. iirc, it should be at least 12.5 with the engine off.
this guide may help
http://www.electrexworld.co.uk/pdfs/Tro ... G-&-RR.pdf
mikey65
Hi great just replaced battery started first time Cheers.
hardnutdvd
im assuming you checked the reg and stator? if not i wouldn't automatically assume a new battery will fix the prob for long
if it was your reg/rec it'll kill your new battery,
mikey65
Hi
Yes I had also replaced the reg/rect the other week. Everything fine know
