Need to lean midrange
Indiana Jones
- Bike owned: XT600Z,'10 TE250 ,XS650 chop
Just back from the dyno.
My plug and play RVF ram air setup gave me 40bhp.
Something not right.
Not happy,seriously thought the timing was way off until I lobbed on my old NC30 HRC spec carbs.
66bhp with a seriously rich needle/mid range.
I'm running 8ZG(lean afaik) needles with no shim and 142.5 front,145 rear MJ's.
WOT fueling is fine.
Need to lean out the needle.
My options are very limited.
I'm considering running the stock needles with a shim to richen the stock lean spot,and hopefully lean my fueling coming onto the MJ.
Or reduce my air jets to a smaller orifice(already restricted),and drop my MJ a size or 2.
More dyno time rather than a track day tomorrow,I think.
I found a very useful "needle thread" with the needle comparisons.
Anyone running the stock needles in this manner?
Indiana Jones
Re: Need to lean midrange
Stock pilots
No easy option then.
When you say midrange, what revs is it rich at? Is there a chance that you won't be using this midrange on the track?
Indiana Jones
Around 6k it starts getting rich.
Way too rich coming onto the MJ.
I've restricted the air jet back to 2mm from 2.5 and dropped the MJ's back a size to 140f 142.5r
Man,those NC30 carbs make a racket on the pipe,nice.
Getting some info on my ramair setup,so hopefully get that sorted too.
Yeah, I like them. Mine has strong power, very nice.indiaguy wrote:Man,those NC30 carbs make a racket on the pipe,nice.
FWIW I use the 8ZK needles which are the leanest.
Indiana Jones
And where would a lad find some 8ZK needles?
I got mine from yahoo japan, but I haven't seen any for sale in a while.
