vibration at high speed
- hallsie
- Bike owned: NC29
Took the bike out last weekend and i noticed at high speed around 80-110 (ahem Mr officer
) I was getting a steady vibration right through the bike. The wheels are balanced but I have noticed that the bt090's have started to wear flat ( 6 months
) already and I have done very little miles really , I have never felt this before but it seems to be coming through the frame , has anybody any clue as everything is nice n tight and torqued correctly
kate beckinsale....... mmmmmmm
- Davez29
- Bike owned: NC29 forever
Re: vibration at high speed
Could check your chain and alignment, this may give the vibration you have another possibility could be wheel bearings. I have the same Pirelli Diablos that I put on 2 years ago, and apart from the snowy weather I use the bike nearly every day, around 10000 miles so far, front and rear
, the rear does however have that flat spot, mainly due to motorway riding. Will need to change the rear by the summer I suppose.
- hallsie
- Bike owned: NC29
I have a new chain and sprockets on there now so didnt think about that one but was pretty thorough when I checked the alignment when I put it all back together ( tape measure to swing arm etc ) , I will pop it into the local bike shop to get double checked as thinking about it this is the only area where it could possibly be.
cheers
cheers
- petrolhead19
could be something simple like your wheel or wheels are out of balance, sounds like that anyway
Adam
Adam
amorti
- Bike owned: CB-1, MSX125
Yeh, that.petrolhead19 wrote:could be something simple like your wheel or wheels are out of balance, sounds like that anyway
Adam
Or wheel or sprocket carrier bearings.
- petrolhead19
sprocket carrier bearings would make a real horribly crunching sound as your riding along wouldnt neccaserally give a wobble at high speed. my carrier bearings have mangled themselves and mine didnt wobble just made a horrible sound.
Wheel bearing is a possibility, but i would check wheel balance first
Adam
Adam
amorti
On a 600 divvy I had one shred itself and exit as swarf over the chain. By the time it was that bad it certainly gave some vibrations!petrolhead19 wrote:sprocket carrier bearings would make a real horribly crunching sound as your riding along wouldnt neccaserally give a wobble at high speed. my carrier bearings have mangled themselves and mine didnt wobble just made a horrible sound.
Adam
That's the problem with don't-care-about-it hacks, the usual method of diagnosis is to wait til the problem becomes very apparent.
