Changing coolant
brmoore
Bike owned: 125/250/400/600/1000
Changing coolant
Post by brmoore »
Well I'm in South Africa so I think it's safe to assume it's not been done at all so I'm going to do it, there arn't any torque settings with any of the drain plugs are there? The rest I've got sorted, got Castrol coolant.
Re: Changing coolant
You'll not need to use the front drain plugs - ust the one on the water pump.
distilled water and coolant.
How cold is it going to get where you are? If not very, then I'd go for a 75/25 water to coolant split - water is better at transferring heat and the coolant will mainly stop the water rusting the insides of the bike.
Dispose of the old stuff carefully - it is toxic to dogs and they love the smell of it
Think the torque is something like 10nm - very small torque
brmoore
Post by brmoore »
Coolant is premixed, and no dog ;) I've heard this stuff is good for zub zero to over 40C easy, on landrovers anyway so we'll see...bike knowledge here is crap so I doubt it's ever been done....just hopefully not over 17years! :o well it would have started its life in Japan so probably not...
car coolant and bike coolant are not the same animal..
car coolant often contains silicates (sand) that will erode your water pump in a bike...
You want silicant free coolant ;)
amaechizzle
Bike owned: NC35
Post by amaechizzle »
Food for thought!
Does bike coolant come in different colours to? And should I stick to the green stuff?
brmoore
Post by brmoore »
No this is corrosion resistant designed for aluminium radiators and as for different colors, green? mines pink ;)
But does it have silicants/silicate in it?
I'd not be keen to use it if that was the case..and I'd stick to water!
brmoore
Post by brmoore »
It's for this type of engine, it contains the appropriate liquids, provides corrosion protection, made for aluminium surfaces. It's castrol, liquid engineering ;)
Hadies
Post by Hadies »
But does it have silicants/silicates in it?
porndoguk
Post by porndoguk »
i use silkolene coolant additive,
50/50 mix costs about £10 for a litre so bang on for the NC30 :up:
