Using Plastex
Hadies
Using Plastex
Post by Hadies »
Hey guys. Just bought myself a small black plastex kit from ebay to repair a snapped lug. I've still got the lug but would you mould a new one with plastex or is it strong enough to just 'glue' the old lug back on?
This isn't my fairing (just a picture I've taken from dx4's for sale thread). The lug in question is circled. its a clean break along the bottom of it.
porndoguk
Re: Using Plastex
Post by porndoguk »
Q Bond ;) is incredbly strong,
re-inforce with fiberglass and resin also
Hadies
Re: Using Plastex
Post by Hadies »
Cheers Ricky. I've attempted to repair the lug before using super glue sprinkled with bi-carbonate soda. The soda acts as a catalyst and a filler and it sets rockhard in literally 2 seconds. I put a hefty amount of this on and around the lug but it snapped back off after taking off the fairings a couple of times. The problem with using super glue type material I think is its too brittle and doesnt offer any flex which is why I think it snapped off eventually. Im assuming that Q-bond is also cyanoacrylate based like super glue though, it may be more flexible.
I've considered plastic welding too. Mate has a soldering iron. I have some cable ties. It could work.
uber pikey
Bike owned: NC30, GS700e GSX750 katana pop
Re: Using Plastex
Post by uber pikey »
I bought the same stuff mate, I however didn't have the old piece as it had snapped off and disapeared. I molded mine from and old fairing and it worked a treat. My advice to you would be to 'V' channel the crack and pour the plastex in then turn it over and do the same to the other side.
I saw it so I took it!
wangwang
Re: Using Plastex
Post by wangwang »
Stick it back together, make a mould of it using plasticene, snap it back off again, use a dremmel or similar to roughen the broken edges so that there is a fine visible gap, fill this with plastex, when set trim any excess with the dremmel, job done!
I've used it a good few times now, it's very strong once set so long as the edges are roughenend and dirt/grease free.
Avoid getting any liquid on visible paintwork it will ruin it.
wang
