VFR 400 NC30 cuts out when low on fuel
VFR400-NC30-SWEENEY
- Bike owned: VFR400 nc30
Hi guys, I took the bike out for a long ride, around 160 mile the other day when bike started to slightly shudder, carried on for around a mile then completely cut out on the motorway! Checked fuel around 2-3 liters still in there, put it on reserve ran fine, topped up no other dramas, any ideas?
Re: VFR 400 NC30 cuts out when low on fuel
Sounds normal, it ran out of fuel and you put it on reserve and it worked..
the normal fuel tap uses a taller "straw" than the res and so once the fuel level drops below the taller straw you got no fuel..
VFR400-NC30-SWEENEY
Good to know, was thinking of cleaning the tank out a bit anyhow just to make sure theres no gunk or anything obstructing. Is there a specific product i should use or am I alright unbolting and cleaning with water, or just flush wit petrol?
Thanks 4 reply
Thanks 4 reply
I would not do anything with it. Fuel is the best thing for fuel tanks and the knack of switching to reserve will come!
niteblade
- Bike owned: NSR150SP, RVF400
mmhm.. yup. theres no problem there. my nc35 has roughly 2-3 litres of reserve. it cuts out once i hit reserve, thats when i know i need to hunt for a petrol station soon.
