Wanted: NC29 rear wheel spacers.
Need these so I can get a 29 wheel into my 23 asap, anyone got a spare set lying around I can swap for moneys?
Or even just the dimensions would be grand.
Cheers.
Cheers.
Re: Wanted: NC29 rear wheel spacers.
they are 10mm wide per side...you could copy the 23's dimentions for shape.
stimpy
stimpy
Cheers Stimpy, if I've got time now I should be able to make my own.
I did wonder if I placed the 29 wheel in the swing arm and took some measurements I could make some from that, but the swing arm 'opens' fractionally as you slacken the spindle nut so I figured that wouldn't be any good.
