reverse sprint mount kit price?
lizard821000
done a serch lads but just keep bringing up old threads with diff pricings!? anyone actually know the current price for one of these reverse mount kits for the sprint sterring damper? and where to buy one? cheers very much.
shaun
also, is it best to do the reverse connection?? or is standard fine?? whats best and whats the diff in reverse n normal mount prices, cheers guys
shaun
lizard821000
Re: reverse sprint mount kit price?
soz for the rush, any takers? dont fancy having the thing an inch from my knee cap. can the damper be turned the other way without the reverse kit at all?? sound silly i know but i think i saw someone do it on here!? will it hit/knock anything up the front end ? cheers
gonzothegreat
don't know about the price, but contact Rick Oliver
viewtopic.php?f=22&t=23826&p=167408&hil ... er#p167408
lizard821000
cheers gonzo....yeah i see that thread earlier. iv found the price now too, £40 for the bracket. so can the damper not be fitted with the adjuster at the front without the rick kit?? or is it possible without? would i have to move my clocks/anything upfront for instance??
cheers
cheers
lizard821000
cheers
cheers
gonzothegreat
sorry no idea about that, ask RO.lizard821000 wrote:so can the damper not be fitted with the adjuster at the front without the rick kit?? or is it possible without? would i have to move my clocks/anything upfront for instance??
- banoffee
I've tried it - not possible with stock amount of lock and a 140mm sprint damper.
lizard821000
cheers banoffee, exactally the info i needed mate
so how much stroke am i gunna need realisticly?? if i want to mount the damper reverse.....
i keep seeing 120mm strokes,130mm and 140mm
is it just a case of using the lock you have once the dampers fitted and living with it!? suppose you ll only miss the extra lock around town and low speeds etc.
can a 120mm stroke be used on a nc30 fitted normally and reverse!? sorry, im just so confused about whats standard after seeing so many diff dampers with all diff stroke lengths too for the vfr.
cheers
cheers
- banoffee
140mm retains full lock. just. I wouldn't want to run less stroke/loke on a road bike personally.
lizard821000
cheers mate, so im looking for a 140mm stroke.
that cleared that up.
shaun
shaun
