chain keeps coming loose
kevin wilson
hi guys,,i have a problem that is doing my head in lately,,my chain keeps coming loose and i dont kno why as i have everything tightened up good and proper,,has any one here ever encountered this and know of a soloution to it please
kevin wilson
Re: chain keeps coming loose
and just to add its a brand new chain and sprockets added to it aswell,,can the hub adjuster slip like this
- alexwitham
The chain is probably just wearing in. Pretty sure I had to tighten mine every 50 miles or so after fitting new C&S's.
arsey30
- Bike owned: ftr223 650 bros
The chain will likely tighten if the hub slips whilst riding, look where the hub lies in the swinging arm, but doubt if it moves when bolt is tightened.
Check slack in all positions for loose/tight spots.
Check tension after hub pinch bolt is tightened, as sometimes hub turns round when the bolt clamps up the hub.
Dave.
Dave.
- CRM
if its one of those "elastic" chains on ebay made by triple S or some other dog shit brand for around £3 then take it and throw it away before you get hurt and replace with a proper chain.
after losing a chain at speed, it's not something i skimp on now. and the tszubaki i have on my 750 has never needed adjusting in 2 years and 3k
amorti
- Bike owned: CB-1, MSX125
Agreed on this. Tsubaki (B+C's favourite barnd) chains are ace. I had a gold one on my last CB-1 and it was mint.CRM wrote:if its one of those "elastic" chains on ebay made by triple S or some other dog shit brand for around £3 then take it and throw it away before you get hurt and replace with a proper chain.
Careful that you are not over tightening it. Remember that as the suspension moves through its travel the distance between front and rear sprockets increases. The chain will stretch very quickly to match this if you overtighten it. This is the fastest and most galling way to knacker a chain.
Conica
- Bike owned: VFR400 NC30 91'x2 Zxr750L2'x1
Use a marker pen to stick a small mark on the hub and swingarm, and then youll be able to tell I'd the hub is slipping as the lines will move out of alignment.
I agree with the chain comments, don't skimp out on them.
And new chains WILL stretch to an extent
kevin wilson
thank you guyz for the helpfull input.i'll put it down to been a new chain and it bedding its self in for now.just to add its a cz x ring chain i got off ebay.wouldnt be too sure on there quality but belive bmw use them on there bikes
