pic request
- mo haggs
- Bike owned: bikeless
pic request
would anyone have a pic of an nc 21 sprocket cover?
any help appreciated
Re: pic request
coming up.. what you planning or need to know?
The NC21 uses hydraulic clutch.. you can see the space for the clutch slave cylinder to go.
If you want to use this on NC30/35 you need longer pushrod.
You also need to modify it for Speedo drive if on 30/35 or move speedo drive to front wheel..
my NC35 project has this sprocket cover but cut off where the gaps are and nc35 sprocket cover welded to it to make it work for both..
- royster81
Re: pic request
What are you planning?
- mo haggs
Re: pic request
im thinking of vtr1000 brake and clutch master cylinders
with nc21 clutch slave cylinder, push rod and sprocket cover
as for speedo -
i believe one of the koso units replaces one of the disc bolts with a magnet for a pic-up mounted on the fork leg
please share your thoughts.
as for speedo -
- royster81
Re: pic request
I like the whole hydraulic clutch idea and I like it even more when the 2 covers are welded together so you can use the stock speedo design so I say got for it
- mo haggs
Re: pic request
dont think i want to chop and weld as i plan to run non standard gearing
so i think the koso speedo is the better option
yeah i fancied a hydrolic clutch for my gammy hand (plus the vtr clutch and brake mc/res match)
and would be a nice touch to sp1/2 front callipers
- royster81
Re: pic request
Neo, who did you welding and have you any pictures of it finished also where can I find an nc21 cover?
