Help - No rear lights!!
Jonesy01
Post by Jonesy01 » Fri Feb 18, 2011 12:26 pm
Hi all,
After having the ignition off the bike to have a new key cut and plugging it back in I have no rear lights or indicators....the front light is fine but the front indicators are on constant.
I have also had the tail fairing off to charge the battery but only had to disconnect the relevant light plugs for this too.
Fuses are all good and I have a live to the rear lights.....I'm guessing its earthing out somewhere on the front but I'm not good with electrics!! I know this could be a world of electrical gremlins....
Any guidance or suggestions are more than welcomed,
Thanks chaps
code2006
Post by code2006 » Fri Feb 18, 2011 2:04 pm
Ty the earth cable on the right hand side of the bike. I think u have to remove the right mid fairing and the cable is bolted onto the frame were the fairing bracket it. I think the wire is a green one and there's to cables that go into one
dirty30-2008
Bike owned: NC 30, TZR 250
Re: Help - No rear lights!!
Post by dirty30-2008 » Sat Feb 19, 2011 9:25 pm
What have you disturbed? Ignition block connector and tail block connector. I have put the tail back on many times and had no tail lights , believing the connector was fully home, so this is where I'd begin. As for the rear indicators check the bulbs visually, switch them with the front ones. if they are okay, check their connectors are fully home. Haynes suggest you check for a voltage at the relay and then for continuity from one end to the other, but hopefully you'll have sorted it before it gets that far.
Regards,
Rob.
thunderace
Bike owned: R6, YZF600R
Post by thunderace » Sun Feb 20, 2011 10:21 am
Just out of interest, is your bike an import?
