Is it common for vfr's not to find neutral...
sotto
Post by sotto » Fri Feb 11, 2011 1:03 pm
Hi,
Is it common for vfr's not to find neutral when selecting it and when the bike is idling...its not something major just a point of interest cos i've been trying like hell at the traffic lights and no luck, but when the bike is cold and i try before i start it slides in, easy as pie.
I've adjusted my clutch (on the clutch lever side) so that it engages quickly when i release the clutch lever, it suits me fine, but could be affecting me selecting neutral.
If it is common then nevermind (if you know please explain), but i have to ask, thanks.
Smev
Bike owned: NC30 of course
Re: Is it common for vfr's not to find neutral...
Post by Smev » Fri Feb 11, 2011 1:06 pm
Yes its very common mate!!!
I've had that issue with all my NC's
I find a blip on the throttle helps to try to engage it, while holding the clutch in and a bit up upward pressure on the gear lever.
:grin:
Mister Donut Rep NC30
Post by Drunkn Munky » Fri Feb 11, 2011 1:08 pm
Check where the shift lever clamps to the spline by your left foot, the dot on the spline should line up with the cut out on the clamp. If its not this can cause the problem.
sotto
Post by sotto » Fri Feb 11, 2011 1:17 pm
Smev wrote:Yes its very common mate!!!
:grin:
I'll admin that this does work for me, but i see it as a temp solution, i'll look for the dot and adjust accordingly. :up:
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 » Fri Feb 11, 2011 2:21 pm
The clutch plates can wear grooves in the clutch basket, causing the plates to wedge and bind.
The grooves can be files smooth or a new basket fitted, depending how deep the grooves are.
Try snicking into neutral just before coming to rest, sometimes it is easier to engage neutral from second gear, not first.
Rolling the bike back and forth sometimes helps whilst trying to engage neutral.
Dave.
hunter
Post by hunter » Fri Feb 11, 2011 7:19 pm
When i bought my nc30 new it had the same problem.
sotto
Post by sotto » Fri Feb 11, 2011 10:46 pm
hunter wrote:When i bought my nc30 new it had the same problem.
That's off-putting for me anyway. But I guess I can live with it, I'll try to adjust to gear selector and shaft properly so they line up if that doesn't work, and I'll check the clutch basket for ware and tear, if all is well then so be it, no use trying to flog a dead horse. Guess you guys won't be hearing from me for a while, so much to work so little time.
Thanks gents for the heads up.
arsey30
Post by arsey30 » Fri Feb 11, 2011 10:54 pm
If the clutch basket is worn, the clutch will drag and try to pull the bike forward when in gear with the clutch lever pulled in i.e disengaged.
If it does not, and you can let the clutch in [lever] part way without it engaging, then the basket is not the problem.
Dave.
tanto
Bike owned: NC30, Raleigh Chopper
Post by tanto » Sat Feb 12, 2011 12:58 am
Thanks. That's re-assuring for me! Same issue with my bike. Finding neutral is more problematic when the engine is warm, but one throttle blip and it slips in fine. I guess it's something to do with the gearbox/clutch design?
sil3nt
Bike owned: GPX 250, NC30
Post by sil3nt » Sat Feb 12, 2011 3:40 am
I've had my NC30 just over a week. Took me a week to get around to searching this site and finding that it's normal and all you need to do is blip the throttle to around 3k rpm and it goes straight in! Was very annoying for that first week :whistle:
