NC35 de-restrictor???
Re: NC35 de-restrictor???
You don't need a resistor on nc35's, just the wiring mod that you've done.skinnydog0_0 wrote:I have a standard CDI and have done the orange wire splice to the battery; seems to work![]()
That's not a stupid question.Variablevalves suck wrote:Forgive the stupid question but how did Honda restrict the NC35 to the 53 bhp that was introduced in 1993, is this quick/easy to remove to get the earlier pre 1993 60 bhp .
The smaller carbs may have knocked a couple of horses off the top end, and the standard muffler is a lot more restrictive than the nc30 muffler. The rest of the exhaust system is probably slightly better flowing than the standard nc30 system, it certainly looks it. At one stage my nc30 had an nc35 standard system and muffler (for reg purposes), and the lack of power was incredible.
I doubt that the ignition curve was modified to achieve a lower power rating (which would have been the easiest way to lower the power rating) as nc35's with decent mods and standard cdi make good power.
Also, I suspect that the rvf engine makes more than 53hp stock (most dyno figures are at the wheel etc)....
nc35's can be brought up to 'full power' (and more) by fitting a good exhaust system and muffler, and jetted to suit. Simple.
